Old 17th September 2019, 04:08 PM
I don't recall the relay setup, but the solar power circuit in a D2 totally bypasses the hedgehog and all other controls and basically just connects the panel straight to the fan motor.
It really is a simple setup; I think Ian (IT) documented the retrofit here long ago.
I only really looked at the circuitry in order to fit a cutoff switch, which I placed in the earth side of the solar panel circuit. Easily accessible around the front passenger footwell.
My (failing) memory says that I thought the relay was actually in the HVAC unit, but it may be that it's an external relay and the HVAC controls it.
Either way, the D2 relay is in the more complex +ve circuitry, which is why I went for the solar earth for my switch.
I would expect (hope) that the D3 didn't "reinvent the wheel" so follows a similar pattern/logic.
My fan motor problems (currently not manifest) were equally evident in either mode by the way.
