Thread: Blocked Drains
View Single Post
Old 17th October 2019, 02:36 PM
irelandbuyer irelandbuyer is offline
HI All,
Can I urge caution when using garage air compressors to clear out the drains. If they are extremely blocked a big blast of air could blow the drain pipes. It is much better to try to access the end of the drain plug have a look there and see how clogged it is.
I bought a hand weed killer pump sprayer (the ones with the srap on them) from I think Aldi or LIdl, took the spray head off which leaves the brass tube. This actually fits perfectly into the drain hole in the sunroof. Pump up some pressure, not too mad and that'll drain it. I use warm/hot water with some mild detergent until i see it is running clear. I just keep it in the garage and i do it every now and then...
Good luck with the drain cleaning...i must go and do mine again soon...
2007 Audi A8 D3 3.2 FSI
