View Single Post
Old 5th November 2019, 06:26 PM
I thought I would have a look at my heaters as they are both dead. They are easy to remove - it takes 60 seconds.
I was hoping to replace the element as you can buy various 12v heating elements from china.
1. slide the front seat all the way forward.
2. Pop off the two round plastic nut covers.
3. Remove the two 10mm nuts.
4. Lift the flap of carpet at the front and back and you will see how it needs lifting at the back over the studs and it is inserted into a duct at the front.
5. Undo the electrical connector at the side/front. Typical VAG type type. Push it in hard, press the tab hard with your thumb until it clicks in and then pull the plug out. If it doesn't come out, repeat but lever it out to unplug it while still squeezing the tab.
6. Lift at the rear and withdraw.
Well, inside the house, I split the two casing halves which are held together along it's seam by 6 metal spring clips.
What a terrible design. It works by overheating several transistors with heatsinks attached! There is what is possibly a blue bead thermistor to give temperature feedback, and maybe a thermal fuse. It is all potted in black epoxy which make it's hard to reverse engineer, if not impossible.
What a joke. It is worth about £5 each but Audi charge £200 each and they don't last at all.
I am thinking of breaking it all out and seeing if I can remake the original design with new components.
While I was taking them out, I sadly found both to be wet and the foam insulation under both seats sopping wet. I have the pleasure of looking into that now. I have no sunroof, so hoping it's the A/C drains.
Attachment 22355
Attachment 22356
Attachment 22357
Attachment 22358
Attachment 22359
Looking at the wiring diagram, we have:
PINOUTS
1 Switched 12V
2 LINBUS signal
3 LINBUS ground
4 Ground
As it has LINBUS connections, there is no way to turn on/off/regulate without retaining the circuit that is hidden in a trough of epoxy.
Attachment 22360
