Old 11th October 2010, 12:43 PM
GlynH GlynH is offline
Default 2001 S8 Lambda Sensor info please?
Hi there,
Just getting ready to spend some money on my S8 and was wondering if some kind soul could advise on the following error please?
I am guessing this points to both pre-cat Lambda probes but want to be sure.
It would also be a huge help if I knew the part numbers of the correct Lambdas...wish I had access to ETKA, ELSAWin etc. etc.
Can anyone help with that also please?
Fault codes below;
----------snip----------
Thursday,16,September,2010,08:03:42:23606
VCDS Version: Release 10.6.0
Data version: 20100630
Address 01: Engine Labels: 4D0-907-560-AVP.lbl
Control Module Part Number: 4D0 907 559 C
Component and/or Version: 4.2L V8/5V G 0003
Software Coding: 10753
Work Shop Code: WSC 02314
Additional Info: WAUZZZ4DZ1N013077 AUZ7Z0Y1749867
VCID: 2E574731C07C
2 Faults Found:
17521 - Oxygen (Lambda) Sensor; B1 S1: Internal Resistance too High
P1113 - 35-10 - - - Intermittent
17539 - Oxygen (Lambda) Sensor; B2 S1: Internal Resistance too High
P1131 - 35-10 - - - Intermittent
Readiness: 0000 0000
Thanks & kind regards,
-=Glyn=-
