Old 8th December 2019, 04:21 PM
These illustrations may help out as well. One is from the current diagram PDF with a reference to J207, and the second is from ETKA showing in which board it's located in the footwell. I've included the part number in the illustration to confirm the correct relay, which a quick search seems to show it as a tall black relay with 297 stamped on top.
Sean are you sure about the ETKA illustration?
That gives a part number of 443 927 351 B which it describes as "Control Unit for Gearshift Lock". Isn't that the thing that stops you moving the gearstick unless you put your foot on the brake?
And what A8Parts are selling is "Audi A8 D2 Shift Lock Control Relay 443927351B" which isn't exactly clear either. Or did this all change between PF and FL and it's the same relay doing a different job?
Didn't MJ say earlier something about it not being where it was documented? Yes:
I don't appear to have a photo of it unfortunately. Its J207 which Elsawin claims is top left in the relay panel in the footwell. I remember it being more in the middle of that panel tbh.
