View Single Post
Old 8th December 2019, 05:00 PM
Originally Posted by B@fink View Post
If the F125 checks out, have you checked the main battery cable on the drivers side chassis? When that corrodes out you have power to everything but no starter action. If it’s getting crusty (damp and salt won’t be helping at the moment) it might start causing intermittent no start?
+1 for the earth strap. I changed a starter motor on my drive before I found that corrosion on the cable to chassis was the problem!
