View Single Post
Old 18th December 2019, 11:47 AM
I've found another subtle but "challenging" difference between genuine and copies, in the diaphragm.
The edge of the main diaphragm is tucked into a slot in the "lid". The bottom half of the case has a fairly sharp edge that presses down into this slot to seal that edge very firmly.
BUT the shape (cross-section) of the edge strip is subtly different; the copy is pretty much square (about 2mm each way) but the OEM is tapered down into the slot, overall it has maybe 25% less material there.
This taper makes it easier to compress and seal; the copy is much more difficult to compress and makes it very difficult to snap the case shut.
I tried fitting a copy diaphragm into the OEM case and just couldn't get it closed at all! In the end I worked carefully around the edge of the copy diaphragm with a craft knife and pared off a sliver of material. Probably a bit too much as the diaphragm didn't then fit securely. But it enabled me to close the case properly and it tests as airtight.
