Old 3rd January 2020, 04:29 PM
Ronin Ronin is offline
Exclamation Update!
The above part did not fit and I returned it.
Part 4B0971841F which is a VAG part fits the hole behing rear right lamp, its a proper snug water tight fit. This grommet was found on an audi A4 from 2006. If you trace negative alternator cable up to the battery you will find it in the bulkhead:
I also found a Suzuki part to fit the rear boot lid I will post a part number, location on the donor car and pics in another post shortly.
