Old 7th January 2020, 04:45 PM
classexa classexa is offline
If you are resetting each time, and all those errors are coming back - I would focus on the low voltage ones as it shouldnt be flagging up voltage errors on a good battery.
If you don't have a good battery and stable voltage, all kinds of weird things can happen.
if the battery is good, it might be a faulty or mis-calibrated power module....
You could try disconnecting the battery, charging it to full and then recoding the battery module to get things back in sync if it is definitely a good battery.
I wouldn't waste time diagnosing anything else until the power is stable....
The low voltage codes doesn't show up on my latest scan(1st post). Did a scan when I bought the car. Cleared the codes and went for a drive and scanned again(3 days later). The scan in my latest post is the 1st scan
But I will disconnect the battery and charge it
A8 D3 2003 4.2 Quattro Engine: BFM / Gearbox: GNU
