Old 16th January 2020, 03:24 PM
Originally Posted by Davey Blueeyes View Post
That's interesting. I wonder where you could attach the antenna, I'm assuming it's not magnetic if it's supposed to attach to an aluminium car??
The SATNAV/DAB unit i fitted to my motorhome used a self adhesive DAB aerial on the windscreen. Reasonably discrete and I ran the cable up the pillar. Only trouble with A8/S8 heated windscreens (where fitted) is that they effectively screen the aerial. A standalone satnav just wont pick up the (weak) GPS signal inside the car but DAB signal strength may be sufficient. I might try out a portable dab radio in the car to see if it works.
