Originally Posted by HPsauce
Engine measuring block Group 66 in VCDS is the brake pedal.
The switch should have a value of 1000 when untouched.
A VERY LIGHT touch on the pedal (engine off) should change it to 1010 but the slightest bit more and it goes to 1011.
I needed to do a scan so after that I checked this out while also monitoring the brake light.
I can confirm that the brake lights only come on at stage 2, i.e. 1011, so at 1010 presumably the ECUs know you're just starting to apply the brakes and at 1011 know (if they get/use that signal) that the brake lights are on.
It's only a tiny bit (on my car) after 1011 that the brake pedal goes hard without the servo.
2016 Volvo V40 T5 Cross Country (4WD) with ALL the toys including adaptive cruise etc. etc. Osmium Grey with Blonde/Charcoal leather interior. Polestar performance "optimisation".  (Even rarer than a D2 S8!) Oh, and a brand new engine at just under 30,000 miles on the factory one!
e.g. Cruise control, NavPlus/TV, Bose, GSM, Xenons, Solar roof, Parking sensors, Alcantara/leather everywhere of course.  (internal dimming mirror added later)
