Old 2nd February 2020, 10:06 AM
Make a short double-ended female piggy-back lead and leave both plugs intact.
You actually need a pair of male-male leads to connect a D3 fan to a D2 harness, with a simple blade on each end.
Doing it that way also enables you to easily test the replacement and quickly resolve incorrect polarity.
(I believe the D2 uses 6.3mm blades and the D3 4.8mm, but 6.3mm fit into both the D2 and D3 connectors.)
