Old 23rd February 2020, 09:26 PM
Audifan Audifan is offline
Thats for the horn. Just a different way of doing it between B6 A4 (what the top wheel is from) and the D2. It looks like you're missing some wiring from the S8 wheel. Do you have the small black rectangular plug?
Also, do you have the airbag for the S8 wheel? They are very likely slightly different & tend not to swap between wheels of different generations.
If you can find a B5 S4 or A4 QS that should be plug n play and will have the recess in the bottom for the 'S' badge which can be swapped for an 'S8' badge
Ah ok. It does have the small black plug, it was tucked behind the metal part of the steering wheel. Here is a picture of the plug.
The S8 steering wheel that I bought doesn't have the airbag. The air bag that's currently used on this car looks like a D2 S8 air bag. I know that doesn't mean anything without a part number to compare it against.
Name:	steering wheel 4.jpg
Last edited by Audifan; 10th November 2020 at 01:00 AM. Reason: added missing picture as attachment
