Old 28th February 2020, 12:37 PM
IT D3 IT D3 is offline
it's not usually the ABS block that causes the issue is the actual electric module that causes problems.
you can replace just the ECM if I remember correctly. However, if you're buying this used, they often come attached and sold as 'one'.
You'll need someone quite handy to code it all in once you're done.
