Originally Posted by 27litres
That kit looks like the one you use for the oil cooler housing, not the oil filter housing.
The oil cooler leak is one of those Audi V8 failure points you need to watch for, but it's not relevant to an oil filter change.
This
The gasket is not available on its own any more - only in a full kit for the oil cooler itself, which no one ever changes so most of the kit goes in the bin
I've found a chap in Poland who is reproducing these gaskets for considerably less than Audi charge so I have a couple to test.
On the 32V the oil filter cap is held on with a long M8 bolt so no need to buy a 36mm socket
