Old 15th March 2020, 08:12 PM
As per the thread I made, the modification to the inner lens is needed to allow them to be drawn out from the back. It is just a light Dremel so the garage may be happy to do, based on the info in the link?
I didn't fancy having to take the lens off to change a bulb, but then being LEDs they shouldn't need doing very often!
Andrew's would be the less hassle option, if you don't mind the design
