Old 2nd June 2020, 02:47 PM
Default Pair of D2 Brembo front caliper bolts
Hiya
Found a pair of front caliper bolts in the garage - I recall buying 4 when I needed to drill out the head of a particularly unhelpful bolt on the nearside caliper.
I believe these are part number N10526001
They measure 95mm long from under the cap head to the end of the thread. The threaded section is roughly 51.5mm long.
Bolts appear to be marked as 10.9 hardness and are a 10mm hex key cap head.
These are definitely genuine from TPS. I doubt they were much money, so happy for someone to cover postage cost if they want them
Adrian
