Old 5th June 2020, 10:29 AM
My D2 has RNS C, TV Tuner and had the earlier steering wheel and from memory you have to select the TV as an input rather than having a "TV button" - I swapped in a digibox into the boot early on but the original tv tuner is still there and if i remember correctly had a single input you could plug into for aux rather than having to hard wire in a pair of aux inputs in the RNS Ds ?
Indeed, I did something similar with mine. The older TV tuner with AUX inputs was quite handy from that perspective.
If you rummage hard enough (I honestly can't be bothered) there's almost certainly a post or two here with pictures of Digital TV on my RNS-C screen.
OK, so I did bother, had a moment of inspiration and found it quickly, you can also see the source button is missing TV, the main external clue to an RNS-C vs RNS-D:
