Thread: Bigger brakes
Old 16th July 2020, 08:47 AM
I could get fronts lock up fairly easy on my PF D2 with stock 323mm brakes but they would also heat up and fade after couple of hard braking sessions.
All of my HP2 D2s brake better than my Brembo D2s
Thanks for info and pictures MikkiJayne . Curious if you have any pictures of the B7 RS4 brakes installed on a D2?
Pretty simple really. The adapter is just a piece of 10mm flat bar with four holes in it. Wheel clearance is an issue as the caliper is quite chunky and the disc is quite flat compared to the D2 stock disc offset. I can't remember if 18" Avus clear, but the 20" FE wheels need spacers. ET needs to be 30-35 I think.
They stop very well but these discs are very prone to warping and judder and, at £1000 a set, that can get expensive very quickly! This particular car is going to get updated to C5 RS6 discs which are non-floating 2-piece and which are both cheaper and more reliable, at a small weight penalty. They also have more disc offset so we can move the caliper inboard to make more room for wheels.
ID:	23612   Click image for larger version
