Old 16th July 2020, 04:48 PM
Ronin Ronin is offline
Default It works!
OK people, I'm glad to confirm that the above BMW valve block is a direct swap with the AUDI one and is a much better and sturdier design, even the mounting tab matches and the threaded clip fits the BMW part too. No modifications required at all, the plug from the loom in the seat fits perfectly too.
You should budget around 4h to do the first seat, 2h after that for the second seat.
There is no special tools required other than a zip slider to zip up and then staple the bottom of the back rest as it was done at the factory.
ID:	23616   Click image for larger version
ID:	23617   Click image for larger version
ID:	23618   Click image for larger version
ID:	23619   Click image for larger version
