View Single Post
Old 4th August 2020, 01:16 PM
I forget exactly what I did to mine to get an LED installed, but I think I added on some thin flexible extension wires with a blade connector on one end and a blade socket on the other.
Ditto. The longer tails made it easy then to remove and change lamps. i also just glued plastic tabs on the rear where the originals had broken off.
