Very useful Ainars.  And on studying them a fairly simple correlation:
Basically contacts 1, 2, 3 ,4, 5 and 8 are the same between both types. Pin 6 however is unused on the 10-pin so it has 9.
6&7 on the 8-pin are 9&10 on the 10-pin (P/N signal which is faulty on my car).
1&8 is the reversing light circuit on the 8-pin, so shares pin 1 with other functions. It's separated out onto pins 7&8 on the 10-pin.
It looks like pin 1 has battery voltage on both types plus pin 7 on the 10-pin (to supply the reversing light).
So rewiring shouldn't be too difficult. Unless there are separate fuses on the two power supplies in the later loom.
Additionally I note that:
S is equivalent to 4th gear. (As you'd probably expect)
Pin 2 says "Car in P, N or D".
Pin 3 says "Car in R, N or 4/S".
Pin 4 says "Car in N, D, 4/S or 2".
Pin 5 says "Car in D, 4/S or 3".
I assume this is some sort of 4-bit binary coding picked up by the TCU. I'll work out what it is shortly, unless a younger IT brain beats me to it!
Basically I think pins 2 to 5 tell the TCU what gear has been selected. Pin 1 is presumably power.
The other section of pins control the starter relay and power the reversing light. Both pretty directly, no ECUs involved.
2016 Volvo V40 T5 Cross Country (4WD) with ALL the toys including adaptive cruise etc. etc. Osmium Grey with Blonde/Charcoal leather interior. Polestar performance "optimisation".  (Even rarer than a D2 S8!) Oh, and a brand new engine at just under 30,000 miles on the factory one!
e.g. Cruise control, NavPlus/TV, Bose, GSM, Xenons, Solar roof, Parking sensors, Alcantara/leather everywhere of course.  (internal dimming mirror added later)
