Old 23rd August 2020, 05:35 PM
dangerdred dangerdred is offline
Default Replacement Exhaust Tip
I reversed the car into a very low wall that has damaged driver side exhaust tip. I put the suspension in Lift and took a look underneath and see that the tip is spot-welded to the silencer pipe. Would it be possible for me to have the existing tip removed and a replacement spot-welded it its place? I had a look on 7zap with my VIN to see if the part is available to buy new but see that this part of the exhaust is listed on the website as coming in several different sections clamped together including the end tips being clamped onto the silencer so I'm slightly confused.
Phantom Black 2008 A8 3.0 TDI SE ASB
