Interesting. I will have a look at the other side in a bit
By the way, have you worked out yet how that side is driven? If the shifter can only go as far as D or S does the gearbox move the F125 drive shaft when changing gears automatically and/or when you use manual override (lever on earlier version without S and/or tiptronic)?
Or is it just that on non-S models that's an input (gears 3 and 2) to the TCU that doesn't exist on S models?
Given there's no "1" position I'd guess that the TCU is informed by other means what the gearbox is up to and the F125 switch is purely an input mechanism, but why in that case is it mounted on the gearbox? It must be both an electronic input to the TCU and linked to a mechanical one to the gearbox (PND?), or is it just that directly mounting removes the inaccuracies of the cable linkage?
2016 Volvo V40 T5 Cross Country (4WD) with ALL the toys including adaptive cruise etc. etc. Osmium Grey with Blonde/Charcoal leather interior. Polestar performance "optimisation".  (Even rarer than a D2 S8!) Oh, and a brand new engine at just under 30,000 miles on the factory one!
e.g. Cruise control, NavPlus/TV, Bose, GSM, Xenons, Solar roof, Parking sensors, Alcantara/leather everywhere of course.  (internal dimming mirror added later)
