  #258
Old 4th September 2020, 01:03 PM
Thanks MJ, having never looked at these in detail I'm just intrigued as to how it all hangs together.
I can understand that there has to be input from the shifter to the TCU - Tip+/- for a start, and the kickdown switch and probably many other sensors/controllers.
Presumably there's a link from the TCU to the gearbox (valve body?) to issue commands to change gears etc. does that have a feedback/control element too?
When you say "Mechanical Mode" do you mean just PRND (and maybe S/4) or also 3 and 2, which the F125 is theoretically capable of signalling?
Just wondering how/if the TCU knows when the gearbox is in First gear...…
As for the cluster, presumably FL2 has a different bitmap or coding for the gearbox display vs FL1 as it has more options to display, so it's hardly surprising it gets confused and gives up.
I don't imagine the developers ever considered providing cross-compatibility either way between FL1 and FL2 TCUs and FL2 and FL1 clusters!
