Old 7th September 2020, 11:35 AM
While you had it apart, I don't suppose you had time to test it with a multimeter and confirm which track connects to which pin?
I started trying to work it out logically and did reckon the inner one was pin 1 then pin 2 but the next going out might be 5.....
(Maybe I'll just open up my cleaned up old one and check?)
OK, I've done that one mine, I'll put the details in the other F125 thread, but the relevant bits are:
The 5 sectors from the inside outwards are pins 1, 2, 5, 3 and 4. And the 5 corresponding wires are not in that order....
So the segments with discolorations are pins 2 and 3 which are largely to do with identifying PRN.
