Having cleaned it up and put it back in, I was checking the shifter alignment yesterday using VCDS. Between P & R and R & N the TCU shows 'Z1' and between N and D it shows 'Z2' so those intermediate contacts definitely tell it something different. Presumably its so it can prepare for what is coming next - it apparently can't tell direction, since it can be put in to Z2 from D, and then put straight back in D, but I guess it uses the Z positions to prepare the gearbox for what may come next.
I didn't get the binary code for Z, but that can probably be worked out from the contacts, or observing VCDS again.
Excellent research.  I think that's consistent with what I worked out and documented in post #16 above.  Z1 = 1100, Z2 = 1010.
There should be another code for between D and 4/S. And a 4th code for 4-3 and 3-2 if have that available.
So we do now know that those intermediate positions exist and are recognised by the TCU, though not if it does anything (or what) as a result.
This could be the basis of another useful diagnostics test on the F125, moving the shifter slowly and monitoring the TCU.
Where exactly in VCDS do you find those codes?
2016 Volvo V40 T5 Cross Country (4WD) with ALL the toys including adaptive cruise etc. etc. Osmium Grey with Blonde/Charcoal leather interior. Polestar performance "optimisation".  (Even rarer than a D2 S8!) Oh, and a brand new engine at just under 30,000 miles on the factory one!
e.g. Cruise control, NavPlus/TV, Bose, GSM, Xenons, Solar roof, Parking sensors, Alcantara/leather everywhere of course.  (internal dimming mirror added later)
