Old 21st September 2020, 02:20 PM
homer simpson's Avatar
It was a factory option, but not in the UK brochure as we're not considered a cold climate.
The webasto heater was already present on the Diesels as its used to warm the coolant faster in cold weather to produce warm air in a reasonable time.
This isn't needed on the petrols, so the retrofit is quite a bit more complex as you need a petrol webasto heater first, and then the aux heater pump for the coolant.
Good point, as the petrols heat up much quicker probably not required. Might just look at the heated windscreen retrofit that is still on my list
