  #54
Old 6th October 2020, 05:53 PM
GH77 GH77 is offline
What did you use on the headlights?
Thanks, Jim. Blood, sweat and tears mostly
It's a really nerve wracking process sanding your headlights until they're opaque. Then the next pass with finer grit paper appears to do nothing at all, your heart starts thumping and there's a sick feeling in your stomach as you keep repeating "oh no, what have I done".
I bought the Holts restoration kit and it's okay for the most part. Just work up through the grits, coarse to fine. Didn't like the result using their 3000 grit discs on the drill attachment as it seemed to leave bad swirls and pigtail marks from the edge of the disc. I just did the 3000 by hand using wet and dry in the end. Their paste isn't all that gritty so I added in a little G3 Professional Scratch remover which seemed to help remove the 3000 sanding marks. The wee sponge they give you in the kit is pretty good.
I think I used the Farecla polish on them after that too. Then it was finished using the aerosol sealant in the kit. That stuff is proper slippy btw when it gets on your wooded floor. Family not happy!
Best advice I'll give is to go heavier than you think you should on the first two coarser grits. At 20+ years old it takes quite a lot to get the plastic level to all the pitting. Just need to have confidence that the polishing stages will indeed repair the initial damage you are doing.
The aerosol sealant was enough to do 6 headlights. (I practised on a cracked spare first, did the D3's, and re-did one of the D2's as I wasn't happy with it initially) Can't seem to find the aerosol on its own anywhere.
Washing the insides really helps too, I think. Just be sure to blow dry them somehow as water spots on them quite easily.
It's a time consuming process. I suppose I wasn't in a rush but it probably took most of the day to do the pair properly. I was in there initially to replace the headlight aim motor so the insides got a good clean out too.
ID:	24123   Click image for larger version
ID:	24124   Click image for larger version
ID:	24125   Click image for larger version
ID:	24126   Click image for larger version
ID:	24127   Click image for larger version
ID:	24128   Click image for larger version
ID:	24129   Click image for larger version
ID:	24130   Click image for larger version
ID:	24131   Click image for larger version
2000 FL A8 3.7 QS - Turned 21 years old on 15th March 2021. Ming Blue - 175k miles. I love having a 90's car worthy of 90L of 98 RON! If only they still did 4* fully leaded!
2009 A8 4.2 FSi LWB - Marine Blue - 164k miles. Extras? Too many to list. But I do like the Rear Seat Entertainment . . . . . .
477k miles to the moon and back. 238k to go and between them they'll have made it!
