Thread: Brake Block
Old 21st October 2020, 06:58 PM
Stromaluski's Avatar
The solution to this is different calipers. B7 RS4 calipers work well, but are excessively expensive, as are the discs. Aftermarket calipers can also work well, but again can be very expensive. Tbh there's not really a cheap solution to this which I have found yet, although I keep looking.
Is changing to D2 A8 spindles and using D3 A8 calipers/rotors not an easy solution over on your side of the pond?
-Andrew
1967 Bus
1980 Rabbit Pickup
1992 Corrado
2001 S8
2010 Jetta TDI Cup Edition
