Old 10th November 2020, 05:00 AM
Originally Posted by 89forever View Post
What’s the difference? The light on the drivers side needs replacing so if there’s something better but still OEM then it’s a given
Diffrent design. Will look odd just to change one and a complete set will be £600-1200 depending wether you go new or used. The old ones can be dried out and sealed. If the LED's fail they can be replaced as well, I am in process of a bit of trial and error replacing LEDs as replacements were running at a bit too much current and failing in 3-4 weeks. I have added a resistors now, will see if they last any longer
