David, see if you can identify where phone lines run, do any neighbours have any existing or defunct lines?
They may run overhead on poles but equally underground and there will be "manhole" covers over access points and junction boxes, typically with a BT or even GPO logo on them. Usually manholes are rectangular and big enough to get into and cables typically follow roads to avoid wayleave and access issues.
It's quite common to have a mixture with bulk underground cable feeding to the base of a pole which then has overhead wires fanning out to nearby properties.
And roadside cabinets can be quite misleading, often some distance away.
Probably the only way to be sure is to order a line and fibre broadband from BT and see what the response is. Though I think you said it's only normal "ADSL" that's available.
2016 Volvo V40 T5 Cross Country (4WD) with ALL the toys including adaptive cruise etc. etc. Osmium Grey with Blonde/Charcoal leather interior. Polestar performance "optimisation".  (Even rarer than a D2 S8!) Oh, and a brand new engine at just under 30,000 miles on the factory one!
e.g. Cruise control, NavPlus/TV, Bose, GSM, Xenons, Solar roof, Parking sensors, Alcantara/leather everywhere of course.  (internal dimming mirror added later)
