View Single Post
Old 20th December 2020, 03:23 PM
Ronin Ronin is offline
OK, so with one of the plugs unplugged as in attached pic, I'm getting:
01543 Parking Aid Warning Chime h15
01625 - front parking aid warning chume h22
I can't tell whether the plug I took out is for front or back, but if i remove the other one and plug in the one i took out, vcds can't communicate with the module.
I've also read the measuring blocks for front and rear sensors and they all seem fine?
I will order a new buzzer from Prestige and go from there unless someone has a better idea?
Does anyone know if the buzzer is located behind the cluster on a RHD or somewhere behind the front passenger air bag?
ID:	24891   Click image for larger version
ID:	24892   Click image for larger version
ID:	24893   Click image for larger version
ID:	24894   Click image for larger version
ID:	24895   Click image for larger version
ID:	24896   Click image for larger version
