Old 20th December 2020, 04:15 PM
Unplugging the front -or- rear wiring harness to eliminate 4 sensors at a time is advised during the diagnosis.
This means the plugs on the bumpers, not on the module itself. Both are on the left side clipped to the bumper bar, rear is above the tailpipe, front is under the headlight. Headlight lower trim off and bumper bolts out and you can pull the bumper forward enough to disconnect it.
