Old 2nd January 2021, 10:46 AM
S81 S81 is offline
Default Power steering rad oil leak
Hi chaps I'm doing some preventive maintenance on the s8 ,I have 2 small oil leaks ,one at were the 2 metal pipes connect to the ps radiator( in assuming it's the o rings inside) and the other at the crankshaft pulley seal,i'm going to remove both rads for pulley acess ,but am concerned that I'll have trouble bleeding both systems after rebuilding,they will be off for a month or so (as I'm back to work on Monday) ,should i also change ps pipes now as well ,one them has a dampness on it further away from the rad ?
ID:	24996   Click image for larger version
ID:	24997   Click image for larger version
Daily driver
Previously owned
Audi 80 1986 1.8 white
Audi 80 1990 2.0 red
Audi A4 1996 1.9 tdi green
Audi A6 1.9 tdi 2000 blue
Audi tt 225 2000 silver
Audi s8 d2 2002 fe grey
Audi a8 4.0 tdi d3 2006 black
Audi a8 3.0 tdi d3 2010 black
