Old 17th November 2010, 07:51 AM
GlynH GlynH is offline
Ian,
Only just seen this and many thanks for posting.
I will read, digest and see if I have the courage to try it myself.
Only had the MFSW for 2 years now...
You mention illumination on the MFSW...does the original/standard 3-spoke tiptronic wheel have illumination because mine never has?
BTW the Hybrid TV Tuner works well...thanks.
I believe you originally said you had the harness for it as well...not that I need it for the S8 but it would make my analogue TV tuner a more attractive buy for someone...
I did have to take off the plastic housing around the four antenna connectors...don't suppose you might know the part numbers to suit the hybrid antenna sockets do you?
Maybe I should ask Carl if he has any kicking around...
Thanks & kind regards,
-=Glyn=-
