Originally Posted by steamship
That sounds intriguing. Any info about it posted on here to read?
I thought I had mentioned it previously, but possibly not. Its a mk2 Polo Coupe, with a 3.6 32V V8 fitted where the back seat was, on an Audi Coupe gearbox. It was built by a friend back in 2003, but he couldn't work out a flywheel and clutch solution so sold it on. It then went through a couple more owners and ended up in a field in Oxfordshire being consumed by brambles. I found it mentioned on a forum a few years ago and did a deal to buy it. It has had most of its original Polo parts pillaged for other projects over the years but the custom subframe and V8 engine are still there. It was built before SVA rules, so it actually has the proper engine number and capacity on the V5
Its a 'when I have time' project
Would you have expected anything less from this car?
I was thinking exactly that as I wrote it
Originally Posted by David's8
With all the issues you have with this car, its nice to see that the engine bay is lacquered. At least that is some reward for using the ton of degreaser!
FL1
Its a delicate balance between cleaning it but not scratching the lacquer. At least in an FL2 there's less risk of scratches, but then the end result isn't as pretty.
