Thread: My Murple
  #216
Old 5th February 2021, 09:27 AM
The crud on the servotronic solenoid
Coming together very nicely.
Out of interest if the guaze was damaged, would you have a back-up work around solution for that?
That's actually the aluminium top cover which has been destroyed by galvanic corrosion. It sits on the rubber sound deadening pad behind the rack, and when I removed the rack, half the aluminium stayed put in white powdery oxide form I've given the new one a good coat of Waxoyl to hopefully preserve it a bit and stop the moisture eating it.
If the gauze was damaged I would have acquired some new material and likely printed a new surround for it in TPU. It would have taken a little experimenting, but by pausing the printer at the right point, the gauze could be inserted mid-print and embedded in the material.
Luckily it was intact though
