View Single Post
Old 27th February 2021, 06:54 PM
Echo's Avatar
Echo Echo is offline
There is no recoding needed to go from analogue TV to hybrid.
It is a straight swap over.
However.
Hybrid TV didn't exist in 2004, so, unless you have updated your MMI to the latest 5570 version, it simply won't understand what the device is that you have plugged into the MOST bus, so it will ignore it.....
Aaaah right! Thank you IT
Time to commence battle with HAL 9000 then.
I'll report back on the outcome.
On a brighter note. The number 4 antenna has decided to come out of lockdown.
ID:	25711   Click image for larger version
ID:	25712   Click image for larger version
ID:	25713   Click image for larger version
2004 A8 D3 4E2 3.0ltr Petrol............baby A8
