Old 5th March 2021, 04:27 PM
Echo's Avatar
Echo Echo is offline
Yes, that is exactly what happens.
Also the Nav unit uses Adaptation Channels to set its parameters, rather than using a coding value like other modules. Hence no coding.
You can do a DVD read test by using Channel 065 and value 2 for short test, value 1 for a long test.
Riiiight, thanks Matty.
So the 5570 update was correct in omitting the nav player then?
And, does that mean unofficial discs sometimes don't work because they are burned (instead of pressed), and don't get the proper info for the nav player to recognise it, as Ainarsemms mentioned?
What does a 'read test' do?
Sorry, with technical stuff like this, you have to explain it to me in dummy language
2004 A8 D3 4E2 3.0ltr Petrol............baby A8
