  #58
Old 13th March 2021, 06:04 PM
edinko's Avatar
edinko edinko is offline
Hi guys, i have "found" bolt on solution for A8 D2
aluminium hubs with HP2 front brakes to 360mm discs & dual calliper upgrade from A8 D3 4.2 Tdi or Phaeton MK1 3.0 tdi model. Bolt on solution no spacers, adapters or so.
Today i did not take pictures when i was test fitting on spare hub, because i have literally one pile of 200 different discs and other pile of callipers to find bolt on match, But i will take some photos when install them on my car.
Minimum is 18" wheel, but im not shore wich wheel ET fit.
I knew they fit under my 19" 8.5j ET 45 oem D3 wheels. I will try to measure gap after fitment.
I have put some D3 310mm discs rear and adapters to fit calipers carriers on desired position. Will make thread for them too.
God loves speed.
Earth orbital speed is 107200 km/h.
And someone set speed limit on earth at 50km/h. Well road safety they say. I say that is bad engineering
THREAD WITHOUT PICTURES IS LIKE SKY WITHOUT STARS.
A8 D2 W12 6.0l 2002
A8 D2 2.5 TDI 2000
S8 D2 4.2 V8 1998 Manual transmission
