  #67
Old 17th March 2021, 09:27 PM
Nice and clean
Drain the front diff oil - as with the centre diff, most of it had already escaped.
The left side output shaft will get a new bearing and oil seal as usual
No dirt inside, just drips of dark oil
The gasket is trashed though - it was dripping oil when on its side before I even removed any of the bolts. It has been serviced before so whoever did it probably didn't quite get the bolt torques even.
The magnets are appropriately furry - nothing wrong here
The sump is nice and clean
I'll leave it with the sump off overnight for the oil to drain, then back together with new seals tomorrow, then I'll start on the engine
ID:	25814   Click image for larger version
ID:	25815   Click image for larger version
ID:	25816   Click image for larger version
ID:	25817   Click image for larger version
ID:	25818   Click image for larger version
ID:	25819   Click image for larger version
ID:	25820   Click image for larger version
