Old 26th March 2021, 04:17 PM
Echo's Avatar
Echo Echo is offline
You'll be fine. Going from your previous posts you're doing well with VCDS.
Open 37-Navigation, then Adaptation, read channel 01, write down the current value just in case you may need it, then enter a new value (this will be you wheel circumference in mm), click Test then Save.
The guy in the video can access that info only because the control module lets him. He was working on a newer car platform and it is dependent what is written in the firmware, so it's not a feature missing from your VCDS. The software / firmware in the D3 is generations old now.
Ok, thanks Matty, I think I've got that.
But what will changing the wheel circumference in the Nav module actually do?
I've put my new(17"), and old (20"), tyre details into this calculator:
https://tiresize.com/comparison/
That was inches. This one is mm:
So, I put in 2167.........yes/no?
And thanks for explaining the Youtube VCDS stuff
EDIT: Sorry, can't get the links to work properly. Just click on the inches and mm to compare.
2004 A8 D3 4E2 3.0ltr Petrol............baby A8
