Old 5th April 2021, 11:05 PM
dangerdred dangerdred is offline
Originally Posted by dangerdred View Post
I'll go at replacing both side upper rear arms in the next week or so. Is there a PDF for the service procedure on this? Also, will I have to do the tracking after replacing these?
I've found the Running Gear pdf - I must have skipped over it the first time I was downloading them. I've also ordered two bushings for either side rear arm - as they are a tenth of the price of a pair of new arms.
In videos I've seen of the process I saw the pressing out of the bushes done with a press - which I don't have - but I was presuming I could use a threaded bolt and washer/spacer arrangement to pull out the old bushing and pull in the new one? Has anyone done it this way?
Phantom Black 2008 A8 3.0 TDI SE ASB
