Old 11th April 2021, 10:15 AM
Finally did some measurements.
It was 1.3mA going through each LED with tail lights on and 23mA with brake lights on so no wonder replacement LEDs kept blowing after 3-4 weeks of use as they are rated 20mA. There are 3x 4.7ohm resistors in parallel on one of PCBs which should be 1.6 ohm total, multimeter reads 2ohm. I added 2 and then 2+2 ohm in series in one of the wires and with extra 4ohm current went down to 20mA, I cannot notice any drop in brightness at least not in daylight, will check again when it gets dark.
I will leave it like this for now with a total of 5.6-6 ohm. But will get 3x22 ohm SMD resistors to go in place of original on PCB and replace if LEDs fail again and I need to go in there again. This would give about 7ohm total and bring the current a bit more down to give a bit of margin.
Well it failed again. They did last 5 months which is a wast improvement over 3 weeks they usually lasted without extra resistors. Colder weather have helped as well no doubt. Back to the drawing board, 3x 22 ohm SMD resistors ordered to go in which should get current down a bit more and hopefully last more than year.
