Old 11th April 2021, 12:57 PM
Well it failed again. They did last 5 months which is a wast improvement over 3 weeks they usually lasted without extra resistors. Colder weather have helped as well no doubt. Back to the drawing board, 3x 22 ohm SMD resistors ordered to go in which should get current down a bit more and hopefully last more than year.
If you can crack this and considering the number of D3's out there needing the fix You could make an income off fixing, or getting someone to fix, these.
And I guess your knoweledge will apply equally to other models and makes. Gold mine
