're changing the bushes ,removing the arms is simple if the pinch bolts aren't seized,removing the old Bush's is simple ,I run a hole saw thru the rubber ,opened a hacksaw and put blade thru and reassembled saw and cut the sleeve and popped it out with a screwdriver,10 mins will take all 4 out ,now the fun part ,,i am lucky enough to have a neighbour with a 10 tonne press in his workshop which pressed them in very easy,the big issue was getting them to sit square to get them started ,we filed the leading edge by a mill or so just to help them start square as the arm is alu and the bush kept biting and going of square ,the edge we filled sits out of the arm so it shouldn't matter , 're loading the suspension i did more or less what mj had said ,thou i hadn't thought of disabling the Jack mode
Daily driver
Previously owned
Audi 80 1986 1.8 white
Audi 80 1990 2.0 red
Audi A4 1996 1.9 tdi green
Audi A6 1.9 tdi 2000 blue
Audi tt 225 2000 silver
Audi s8 d2 2002 fe grey
Audi a8 4.0 tdi d3 2006 black
Audi a8 3.0 tdi d3 2010 black
