Old 1st May 2021, 08:44 PM
S81 S81 is offline
I had the same problem ,I used a trolley Jack and a small round bar to apply heavy upward pressure on the pin in the track Rod and then taped the housing gently and prolonged and pin eventually started to move ( it's not that easy to get the bar and Jack positioned to get the strong upward pressure as part of the suspension stops u from getting directly under it)(same as yourself I didn't want to damage the rubber boots ) ,I think I cleaned the corrosion out of the slit with a hack saw blade and sprayed penetration oil into it before hand as well ,when I went to the second side i just rung the head of the bolt right away and pulled it thu with the nut as it seemed to be the only thing that worked on mine
Daily driver
Previously owned
Audi 80 1986 1.8 white
Audi 80 1990 2.0 red
Audi A4 1996 1.9 tdi green
Audi A6 1.9 tdi 2000 blue
Audi tt 225 2000 silver
Audi s8 d2 2002 fe grey
Audi a8 4.0 tdi d3 2006 black
Audi a8 3.0 tdi d3 2010 black
