Old 2nd May 2021, 03:48 PM
dangerdred dangerdred is offline
Once the pinch bolt is out I use a large tapered punch to push the upper arms out. Usually they need to be worked back and forth a bit to break the ring of corrosion around the pin where the pinch bolt goes.
Are you doing this on the bench or on the car?
Phantom Black 2008 A8 3.0 TDI SE ASB
