Old 7th December 2010, 10:59 PM
If you change the engine ECU, you need to recode the immobiliser on a 2000 car as it is bult into the keys, instrument cluster and Engine ECU....
As far as I'm aware, this is an Audi only job. They're unlikely to be happy to fit you a 2nd hand ECU and code it, but in my experience if you fit it, then tow it to Audi and claim your car 'wont start' they should code it up.. ...ah hem...
unless you're real pally with the service manager in which case he might be more receptive to what you need..
I was pretty sure the oil level sender went direct to the instrument cluster though, not via the engine ecu, so it flagging up an error, wouldnt really tally with an engine ECU fault...
Wonder if the gearbox ecu has gone.... its odd that its lit up all the lights like that.... Much easier to change over the gearbox ecu, just plug and play... no coding to worry about...
